ARCGISHOME variable replaced by DESKTOPJAVA94 or AGSDESKTOPJAVA?
3747
04-13-2010 05:00 AM
MarcN
In ArcGIS 9.3 the environment variable ARCGISHOME has been set.
In ArcGIS 9.4 Beta the variables DESKTOPJAVA94 and SERVERJAVA94 have been set.
in ArcGIS 10 Pre-Release the variables AGSDESKTOPJAVA and AGSSERVERJAVA are now available.
The ArcGIS 10 SDK help still describes DESKTOPJAVA94 and SERVERJAVA94: http://help.arcgis.com/en/sdk/10.0/java_ao_adf/conceptualHelp/engine/index.html#//0001000003n1000000.
FrankPerks
In the past i've used the ARCGISHOME enviroment variable to determine the installation location for ArcGIS. So now in light of these changes is there a better way to dig out the ArcGIS root path....?
MarcN
One problem is that there is no variable which points to ..\ArcGIS\DeveloperKit10.0
MarcN
Would be nice to have some feedbackk from ESRI for this topic :confused:
LesleyBross
We opened a support case with ESRI and they recommended AGSDESKTOPJAVA as the replacement for ARCGISHOME in ArcGIS 10.
