ArcGIS Snapping environment
2074
09-25-2012 02:18 AM
prasadprasad
Hi All
Anybody knows is there any way to check or uncheck the vertex or edge or End checkboxe's for a particular layer in ArcGIS snapping environment program-metrically (.NET)
Please find the attached image for more info
Rega
prasad
by Anonymous User
Not applicable
Be careful when using .ClearSnapAgents as it will delete them all which might not be what you want.
The other way to get the featuresnapagent for a layer is to loop through all agents (ISnapEnvironment.SnapAgentCount) then find the one you want by name.
Dont forget to refresh the snapping window after you have changed the snapagent properties.
//refresh snap window UID extUid = new UIDClass(); extUid.Value = "esriEditor.SnappingWindow"; ISnappingWindow snapWindow = _editor.FindExtension(extUid) as ISnappingWindow; snapWindow.RefreshContents();
NeilClemmons
Honored Contributor
Use IFeatureSnapAgent2.HitType.
prasadprasad
Hi Neil
Thank you very much for your reply
I am using following code as i am using ArcGIS 9.1 instead of using IFeatureSnapAgent2 i am using IFeatureSnapAgent but i doesn't check the vertex  checkbox
Please highlight if i am doing anything wrong
Try
            ' Dim pID As New ESRI.ArcGIS.esriSystem.UID
            Dim pApp As IApplication
            Dim pEditor As IEditor
            Dim pSnapEnv As ISnapEnvironment
            Dim pFeatSnap As IFeatureSnapAgent
            Dim pEditLayers As IEditLayers
            'pID = "esriEditor.Editor"
            pApp = m_App
            pEditor = m_App.FindExtensionByName("ESRI Object Editor")
            pEditLayers = pEditor 'QI
            pSnapEnv = pEditor 'QI
            Dim pCount As Integer = pSnapEnv.SnapAgentCount
            Dim p_WorkSpace As IWorkspace = pEditor.EditWorkspace
            Dim pFeatWorkspace As IFeatureWorkspace = p_WorkSpace
            Dim pFeaturecass As IFeatureClass = pFeatWorkspace.OpenFeatureClass("TestFC")
            pSnapEnv.ClearSnapAgents() 'clear all existing snap agents
            pFeatSnap = New FeatureSnap 'create a new feature snap agent
            pFeatSnap.FeatureClass = pFeaturecass
            'pFeatSnap.HitType = ESRI.ArcGIS.Geometry.esriGeometryHitPartType.esriGeometryPartEndpoint
            pFeatSnap.HitType = ESRI.ArcGIS.Geometry.esriGeometryHitPartType.esriGeometryPartVertex
            pSnapEnv.AddSnapAgent(pFeatSnap)
        Catch ex As Exception
        End Try
by Anonymous User
Not applicable
prasadprasad
Yes It worked thank you
