ArcGIS SDK templates not showing up in Visual Studio 2012
10367
10
03-25-2014 08:45 AM
MichaelShaffer
I'm trying to use Visual Studio 2012 and the ArcGIS SDK to make a custom tool. I installed the ArcGIS SDK but the templates don't show up when I go to make a new project in Visual Studio 2012. I reinstalled Visual Studio and that didn't help. Do I have to install something else? I'm running Windows 7 and the 60 day trial of ArcGIS.
Thanks
KenBuja
MVP Esteemed Contributor
Did you make sure that you selected the .NET Framework 3.5 in the New Project dialog?
MichaelShaffer
I couldn't even find the box to do that. I read another post about needing to do that but there was just a search box. No drop down box that I could see. I guess I'll look again when I get home.
MichaelShaffer
Here's a screen shot, I don't see where to select the .NET version.
[ATTACH=CONFIG]32496[/ATTACH]
KenBuja
My version of VS 2012 was set up after installing ArcGIS, so the templates aren't showing up here. But look for the highlighted dropdown in your New Project dialog.
[ATTACH=CONFIG]32497[/ATTACH]
by Anonymous User
Not applicable
What version of ArcObjects SDK are you using?
MichaelShaffer
Hmm I thought I replied yesterday but I guess I didn't hit submit or something. I installed the ArcGIS SDK for .NET. I guess I didn't install the ArcObjects SDK. It looks like I can't since I'm using the trial version. Doh.
by Anonymous User
Not applicable
ArcGIS SDK for .NET is the ArcObjects SDK. What version of ArcGIS are you using?
JoseCorral
I have the same issue, I have VS2012 and ArcGIS 10.2 trial installed. I installed ArcGIS Runtime SDK for .NET version 10.2.4 and I still don't see the arcGIS templates under C#. Even if I select Framework 3.5 I don't get them.
Could you help? Thanks
by Anonymous User
Not applicable
For ArcGIS Runtime SDK for .NET 10.2.4:
  • Supported .NET frameworks are 4.5 and 4.5.1.
  • To get the templates, make sure you have Update 3 for VS, if you plan to use Visual Studio 2012. Then run the SDK setup file again and select VS2012 during the installation.
  • Once the installation is successful, you should find the templates under Visual C# -> Windows, not under ArcGIS.
https://developers.arcgis.com/net/desktop/guide/system-requirements.htm
Mohini
