ArcGIS Engine with Qt IDE on Linux Platform
1297
07-07-2011 05:13 AM
praveennarayandas
Hi
I am interested working with ArcGIS Engine and Qt IDE on Linux Platform.
I have programming skills on Qt on linux.So I want to use ArcGIS Engine
On it. Can anyone suggest this??
whether can i get arcgis control in Qt creator on linux??
Which versions  are supported with arcgis engine 10??
Thanks in advance
Best Regard
praveen
AndreaFlesca
I'm working with ArcGIS Engine on Linux with Qt since some years.
I can guide you through the compilation-build-execution of a simple example.
Do you still need help?
Let me know, or send me a private message.
Greetings from Italy.
RichardSundharam
Hi
I require some urgent help in the compilation-build-execution of ArcGIS Engine on Linux with Qt application.
Please send me whatever info that you can share.
Greetings from India.
AndreaFlesca
Hi, I read only now you request for help.
It's a lucky event, 'cause mail notification seems to NOT work in this forum.
My private address is [email protected] feel free to contact me.
You should have:
- RHEL 5.8 installed on your workstation (unfortunatelu CentOS is NOT ok)
- An ArcGIS Engine RT 10.1 copy to install on your Linux box
- An ArcGIS Engine DevKit CPP 10.1 copy to install on your Linux box
- licenses for these products
- Qt 4.7.3 or 4.8.x libraries (the open source edition works ok)
Well, let me know if you've got this stuff.
Cheers.
