ArcGIS Engine 10 - SDE Edit error
3548
09-07-2011 11:52 PM
by Anonymous User
Not applicable
Original User: choijy725
Error When I Edit Geodatabase.
I don't  understand it. Please help us.
Thank you.
GregRieck
If you want your data to be versioned then you need to open ArcCatalog browse to your Database Connection then select the feature dataset(s) and/or tables then right click and choose register as versioned.
If you do not want to version your data then in ArcMap go to Editor > Options > Versioning tab and uncheck the "Edit a version of the database with the ability to undo and redo." option.
Also, you have a data layer that is not found in your table of contents. Any layer with a red exclamation mark next to it means the data can't be found. Right click on the layer and choose Data > Repair Data Source... to browse to the data's location and repair the broken link.
Here are some helpful links:
Working with Non-Versioned Data
Working with Versioned Data
G
