ArcGIS Engine 10.0 Controls Example / Custom Tool registration
1422
02-13-2012 10:19 AM
GlennNead
Greetings!
I am going through the ArcGIS Engine Controls example (C# version) in the ESRI Resource Center.  All goes well until I attempt to build the Commands project, a custom tool.  It attempts to write to the registry  which fails due to lack of admin privileges.  I thought with Version 10 you didn't need registry access.  Is that true only for desktop add-ins?  How/where does ESRIRegAsm come into play?  Is ESRIRegAsm a custom tool that still accesses the windows registry?
Edit:  Running with Windows XP SP3, Visual Studio 2010 set to framework 3.5.
Thanks in advance!
           -- Glenn
AlexanderGray
Honored Contributor
Add-ins only don't use registry.  ESRIRegAsm still does.  ESRIRegAsm does the same things as regasm plus other things like registering the version and the product.
AlexanderGray
Honored Contributor
GlennNead
I was afraid of that, but thought I'd ask anyway.  Now to convince the powers-that-be for admin privileges if I need to add tools.
Thanks for the prompt reply!
            -- Glenn
