ArcGIS 10 problem with IGxDialog
1163
07-03-2013 05:51 AM
DebbieAlger
Has anyone had the opportunity of updating an AO project from 9.2 to 10.0 and had issues with the IGxDialog object?  I get  a
??? vshost.exe  has stopped working??? error every time I hit the following line
            Dim pGxdialog As IGxDialog = New GxDialogClass()
            Dim mdbFilter As IGxObjectFilter = New GxFilterPGDBFeatureClasses
            pGxdialog.Title = "Pick the feature class you want to use"
            Dim pEnumGx As IEnumGxObject
            pGxdialog.ObjectFilter = mdbFilter
            pGxdialog.StartingLocation = "c:\"
            If Not pGxdialog.DoModalOpen(0, pEnumGx) Then <--ERROR HERE
                Return
            End If
This could also have something to do with Windows 7, because it caused other minor issues also.
FYI, I already disabled the  VS Hosting process in the project debugger and deleted the vshost.exe in the bin folder, which should???ve fixed it, but didn???t
thanks
