ArcEngine import tiff wrong colours
3854
03-17-2016 07:29 AM
PaulCole
Using Arc Engine, I have produce a map handling product for our clients. It takes their low level mapping and produces bit maps at diffferent scales though an automatic procedure.
The software produces Geo Tiff files. I have checked these files and they are correct, but when I do an automatic import of the bit maps, some of the files have their colours changed.
There isn't any rendering on those files, as they are on their own separate layer files. If I clear the map down, and run the import again, different bitmaps have their colours wrong.
I am using the following code to import the tiff file
private ILayer AddBitmap(string mapDirectory,string imageDirectory, string sFile, object minimum, object maximum, IGroupLayer groupLayer)
            IRasterLayer prlyr = null;
            try
                WriteLog("loading " + sFile);
                string layerName = System.IO.Path.GetFileNameWithoutExtension(sFile);
                string lName = imageDirectory + @"\" + layerName + ".lyr";
                if (mapDoc != null)
                    int c = mapDoc.get_Map(0).LayerCount;
                    for (int i = 0; i < c; i++)
                        ILayer layer = mapDoc.get_Map(0).get_Layer(i);
                        if (layer.Name == sFile)
                            return null;
                IWorkspaceFactory pWsFact;
                IRasterWorkspace pWs;
                IRasterDataset pRasterDataset;
                //Open the workspace
                pWsFact = new RasterWorkspaceFactoryClass();
                pWs = pWsFact.OpenFromFile(imageDirectory, 0) as IRasterWorkspace;
                //Open the raster dataset
                pRasterDataset = pWs.OpenRasterDataset(sFile);
                //Open the raster layer
                prlyr = new RasterLayerClass();
                prlyr.CreateFromDataset(pRasterDataset);
                ILayerFile layerFile = new LayerFileClass();
                layerFile.New(mapDirectory + @"\" + layerName + ".lyr");
                layerFile.ReplaceContents(prlyr);
                layerFile.Save();
                int index = axMapControl1.LayerCount;
                if (groupLayer == null)
                    axMapControl1.AddLayer((ILayer)prlyr, index);
                    if (mapDoc != null)
                        mapDoc.get_Map(0).AddLayer((ILayer)prlyr);
                else
                    groupLayer.Add(prlyr as ILayer);
                //Thread.Sleep(2000);
                 if (maximum != null)
                    ((ILayer)prlyr).MaximumScale = Convert.ToDouble(maximum);
                if (minimum != null)
                    ((ILayer)prlyr).MinimumScale = Convert.ToDouble(minimum);
            catch (Exception ex)
                WriteLog("error of " + ex);
                MessageBox.Show("Error\n" + ex.Message);
            return prlyr;
PaulCole
I have now tried it with PNG bitmaps, and I am getting the same results. When I do an identify on the bit map, it says the rgb values re 128,128,128 which is what they are suppose to be at that point, but the colour being displayed is a bright green.
This has to be issue with Arc Engine somewhere, either something not being set up or some other issue.
Can someone please help with this situation. I can supply a copy of the bitmaps in question.
ModyBuchbinder
Hi
Check the stretch on the lyr file.
It might change the colors
PaulCole
Thanks for the suggestion, I will check it out, but I am not changing the default strech value, I have also noticed that when I do an add raster image from the open menu, it also does the same thing, this is a layer that has been created by ArcEngine through the esri add data function.
PaulCole
Can you please tell me where the stretch information is stored, as the only stretch I can find is under the RasterRGBRenderer which I am not using.
ModyBuchbinder
I see it in ArcMap in the layer properties in symbolgy tab.
Not sure how to do it in code. Maybe get IRasterStretch from the renderer.
