[ArcEngine] [DotNet] How to load .hgt files into a dataset and then elevation layer
6977
12
03-13-2012 01:25 AM
ManfredLauterbach
Despite some significant time spent searching documentation and reading the ArcGIS online help and forums I still can't find a solution for this.
This thread is a child of : http://forums.arcgis.com/threads/52661-DotNet-Is-it-possible-to-create-an-elevation-Profile-layer-us...
The objective is to create a dataset from a folder containing .HGT files (SRTM data) programatically, and then to create an elevation layer from the dataset .
Is this possible for ArcEngine?
The closest documentation example I have found only refers to .gdb data file under the topic "How to open a terrain dataset" :
IWorkspaceFactory WSFact = new FileGDBWorkspaceFactoryClass(); IFeatureWorkspace FWS; FWS = WSFact.OpenFromFile("C:\\project\\terrain.gdb", 0)as IFeatureWorkspace;
I have tried working with IRasterDataset in a similar manner to opening raster maps but this is obviously not the correct interface to read elevation data?
What namespace must be used to read .hgt files from a file folder (with the intention of creating an elevation layer later)?
Thanks.
UPDATE [1] : Having a look at the Visual Studio DotNet "Map Control Application" Template, the add data dialog provides for 5 different types of data
1) Shape files
2) GeoDatabases
3) Rasters
4) Servers
5) Layers
but these options do not include support for SRTM data - is there a sample / template available which describes how SRTM data can be imported?
GeorgeFaraj
Much appreciated - thanks for the help thus far.
It seems that the path I'm walking down is not very popular - ESRI undoubtedly wants customers to stick with their flagship products : ArcDesktop, View, Map etc. and customize them only when necessary - instead of using their own SDK to redevelop features.
In our defence I must state that we are upgrading a product which used MapObjects 2.2 - and want to keep functional and interface changes to a minimum.
My bad feeling at this point is that we're still going to be implementing a lot of features ourselves (e.g. terrain profile) if it turns out to be this difficult just to find out how to load STRM data into a data set.
The file loads using the esriControls.ControlsAddDataCommand. (That extension does not show but the file does load.)
NeilClemmons
Honored Contributor
The following worked for me as far as getting the data into ArcMap.  I wasn't able to figure out how to access the data through a workspace though.
            Dim rasterLayer As ESRI.ArcGIS.Carto.IRasterLayer = New ESRI.ArcGIS.Carto.RasterLayer
            rasterLayer.CreateFromFilePath("E:\Development\N10E012.hgt")
            rasterLayer.Name = "test layer"
            DirectCast(m_application.Document, IMxDocument).FocusMap.AddLayer(rasterLayer)
            DirectCast(m_application.Document, IMxDocument).UpdateContents()
As for having to recreate functionality for your app, be sure to investigate all of the builtin tools that Engine offers as well as the geoprocessing library.  There's quite a bit of functionality there may be something you can use in your app.
ManfredLauterbach
Thanks Neil and Charles,
Your success with loading the file prompted me to double check my code again - and to my surprise the problem was exactly what Neil suggested in the first place : the pathname. (so I'm marking that as the solution)
 IRasterWorkspace rasterWorkspace = (IRasterWorkspace)workspaceFactory.OpenFromFile(folderPath, 0);
  expects a folder path.
 IRasterDataset rasterDataset = rasterWorkspace.OpenRasterDataset(filename);
  expects a filename (without path).
One could probably argue that OpenFromFile is misleading (because we're passing a folder path, where the method name is suggesting a filename) - but the documentation does state that the parameter may be either filename or directory. I assume that the forum MVP's have had to suggest this on numerous occasions 🙂
