arc obejcts - string builder
4169
08-02-2015 01:22 AM
SusanneWagner
Hello,
I'm newbie in vb.net and have question about string builder to show the arcgis layers. (System: ArcGis 10.2, VisualStudio2012) I don't succeed to show the loaded layers in a line of the message box.
Thanks for any help in advance!
code:
Imports ESRI.ArcGIS.Geodatabase
Imports ESRI.ArcGIS.Carto
Imports ESRI.ArcGIS.ArcMapUI
Imports System.Text
Public Class LayerLoop2_Button1
Inherits ESRI.ArcGIS.Desktop.AddIns.Button
Public Sub New()
End Sub
Protected Overrides Sub OnClick()
AccessLayerViaMxDocument(My.ArcMap.Document)
My.ArcMap.Application.CurrentTool = Nothing
End Sub
Shared Sub AccessLayerViaMxDocument(ByVal pMxDocument As IMxDocument)
Dim pMap As IMap
Dim pMaps As IMaps = pMxDocument.Maps
Dim i As Integer
For i = 0 To pMaps.Count - 1 Step i + 1
  pMap
= pMaps.Item(i)
Debug.WriteLine(pMap.Name)
MsgBox(pMap.Name)
Dim pEnumLayer As IEnumLayer = pMap.Layers(Nothing, True)
  pEnumLayer
.Reset()
Dim pLayer As ILayer = pEnumLayer.Next()
Dim sb As System.Text.StringBuilder = New System.Text.StringBuilder()
While Not pLayer Is Nothing
Debug.WriteLine(pLayer.Name)
' Show MessageBox with the name of the layer
  pLayer = pEnumLayer.Next()
  sb.Append(pLayer.Name)
  MsgBox(sb.ToString())
  End While
DuncanHornby
MVP Notable Contributor
Susanne,
The reason you are only seeing 2 layers reported is because the sequence is incorrect your code should be:
pEnumLayer.Reset()
End While
To understand this you have created an enumerate and get the first layer, as this not nothing it enters the While loop. It appends the name and then gets the next layer. Your original code had the get next layer code before you ever added it to stringbuilder so this is why it skipped a layer name.
DuncanHornby
Susanne,
When you post code you should use the syntax highlighter in the Advance Editor option then >> button. This will make reading your code easier for others and improve your chances of getting an answer. You can go back and edit your question any time.
That being said looking at your code on each iteration of the While loop you append then print sb, so what is not working?
SusanneWagner
Hello Duncan,
thank you for your answer! I don't succeed to edit the code again but I will do it with next question! For code above he placement of the message box was wrong. It must be placed outside the loop. At least it works but when I put 4 layers in the arcgis toc there will be showed just 2 layers.....
DuncanHornby
Susanne,
pEnumLayer.Reset()
End While
SusanneWagner
Dear Duncan,
thank you a lot!!! It works perfectly now!!
