Anyone seeing PInvokeStackImbalance errors reported when debugging CommandBars.Add arcobjects v10.4 code
3958
05-16-2016 02:09 PM
GaryWalter1
The following code works fine in AGD 10.3.1, but managed debug assistant throws a PInvokeStackImbalance error in AGD 10.4 (ESRI.ArcGIS.ADF.Local!ESRI.ArcGIS.ADF.Native::memcpy). Any fix other than ignoring this kind of exception?
private void LoadCustomizations()
            try
             ICommandBar pContextMenu = GetCommandBar("{7D931EAE-D31F-11D2-9F40-00C04F6BC78E}");
                if (pContextMenu ==  null)
                    return;
                UID pUIDSubmit = new UID();
                pUIDSubmit.Value = "SubmitVersion.cmdSubmitVersion";
                Object indexObj = Type.Missing;
                ICommandBar subVercmd = pContextMenu.Add(pUIDSubmit, ref indexObj) as ICommandBar;
                ((ICommandItem)pContextMenu).Refresh();
                m_isMenuPresent = true;
by Anonymous User
Not applicable
Check out this Technical Article (http://support.esri.com/technical-article/000012655). I believe the problem discussed in Article 000012655 also occurs in 10.3.x version. Based on the Article, I don't think there are other ways to fix it other than unchecking the exception settings, since it appears to be a framework-level issue and there is nothing in the code that we can modify.
