"Stops" does not contain valid input for any route.
1994
05-28-2010 12:42 PM
ashrafelhakim
hi all
when i try to solve my network again..
"Stops" does not contain valid input for any route. error appear in this part of code
naSolver.Solve(naContext, new GPMessagesClass(), new CancelTrackerClass());
JaySandhu
Given that error message, check if you have any stops loaded for that route context.
Jay Sandhu
RobertoTejedor
hi all
Hi ai_elhakim!
I have the same problem. Do you solve this problem?
Thank you very much.
ashrafelhakim
Salam Alikom,
i am sorry i don't remember exactly but it was Network Dataset problem
Just build the Network Dataset again and if this not help
try to generate The network dataset and check if you made something wrong
and if you are not sure ,you can send me The detials about the method you used to generate This ND
Thank you and hope your problem get solve
RobertoTejedor
Thank you very much!
I will try to build again my network dataset.
DeepikaJain
Hey
I am also trying to find the route between the features selected by the user, but i get the same error..even after rebuilding the network dataset.
Please guide me through this.
Thanks
Deepika
