Adding Custom tools to an add-in toolbar
2081
01-13-2011 07:46 PM
JessieParteno
I have created multiple custom tools in VS 2008 and I want to add them to an add-in toolbar but i can't get it to work. When I create the toolbar I tried to add the Guid of the custom tools but they are not showing up in the toolbar when I add it to ArcMap. How do you add multiple custom tools to a custom toolbar?
Jessie
JeffreyHamblin
Are you using the new "Add-in component" wizard to add the toolbar, and then using the "Items" on the wizard dialog to add the buttons? That process should update your Config.esriaddinx file.
I suggest you post the contents of your Config.esriaddinx file here.
-Jeff
RuchiraWelikala
Jessie
Could we see the you're using to implement the GUIDs and which GUID are you using? (there are 3)
RuchiraWelikala
Try out this thread... I asked this same question last year and someone helped me out.
http://forums.arcgis.com/threads/4951-custom-toolbar-vb.net
Best of luck.
JohnHauck
First off, can you find your commands in the customize dialog (did they register correctly)? If not you may need to take another look at the tools or commands. Did you register with ESRIRegAsm? Secondly, use the ProgId rather than the GUID.
Your solutions config file may look like this:
<ArcMap>
      <Commands>
        <Button id="ArcMapAddin1_Button1" class="Button1" message="Add-in command generated by Visual Studio project wizard." caption="My Button" tip="Add-in command tooltip." category="Add-In Controls" image="Images\Button1.png" />
      </Commands>
      <Toolbars>
        <Toolbar id="myID" caption="caption" showInitially="true">
          <Items>
            <Button refID="ArcMapAddin1_Button1"/>
            <Button refID="ArcMapClassLibrary1.TestBaseCommand"/>
          </Items>
        </Toolbar>
      </Toolbars>
    </ArcMap>
