ADD LAYERS TO ARCMAP FROM LISTBOX
843
01-09-2014 02:02 PM
JohnHanson
I am creating an Add-in with ArcGIS 10.1 using MS Visual Studio 2010 VB.net
I have a button on my toolbar that opens a form (frmFieldDescription) with a listbox (ListBox1) that is populated with a list of .lyrs from a directory (G:\PPACG\)......this works fine.
On the form I created another button (Button1_Click).....I've been trying to get this button to load the selected .lyr(s) from the listbox to be loaded onto ArcMap's TOC.
Any suggestions-code?
See my code that is competed so far below:
Imports System.Windows.Forms
Imports System
Imports ESRI.ArcGIS.esriSystem
Imports ESRI.ArcGIS.Framework
Imports ESRI.ArcGIS.Carto
Imports ESRI.ArcGIS.ArcMapUI
Public Class frmFieldDescription
    Private Sub frmFieldDescription_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
        Dim directoryInfo As IO.DirectoryInfo = New IO.DirectoryInfo("G:\PPACG\")
        If Not (directoryInfo Is Nothing) Then
            Dim fileInfo As IO.FileInfo() = directoryInfo.GetFiles
            Dim i As Int32
            For i = 0 To fileInfo.GetUpperBound(0)
                ListBox1.Items.Add(fileInfo(i).Name)
            Next i
        End If
    End Sub
    Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        MsgBox("nnnn", , "Oops")   'JH at least this works
        'JH THE FOLLOWING WORKS WHEN I CLICK ON THE BUTTON
    End Sub
    Private Sub ListBox1_SelectedIndexChanged(sender As System.Object, e As System.EventArgs) Handles ListBox1.SelectedIndexChanged
    End Sub
End Class
