I have Visual Studio 2010 Professional and ArcGIS 10.1.
Here is code, all of which was automatically created by Visual Studio when the dockable window was created; the code file name is "ArcGISAddin3.cs" as shown in the Solution Explorer:
namespace CustomUIElements
partial class TestDockableWindow
/// <summary>
/// Required designer variable.
/// </summary>
private System.ComponentModel.IContainer components = null;
/// <summary>
/// Clean up any resources being used.
/// </summary>
/// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
protected override void Dispose(bool disposing)
if (disposing && (components != null))
components.Dispose();
base.Dispose(disposing);
#region Windows Form Designer generated code
/// <summary>
/// Required method for Designer support - do not modify
/// the contents of this method with the code editor.
/// </summary>
private void InitializeComponent()
this.SuspendLayout();
// TestDockableWindow
this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
this.Name = "TestDockableWindow";
this.Size = new System.Drawing.Size(300, 300);
this.ResumeLayout(false);
#endregion
Thank you.
