Add-In to change MXD Data Source Only Works if User Saves & Exits MXD After Execution
3529
6
03-26-2014 08:47 AM
E__C_Roman
Hello,
I have created an ArcMap 10.1 Add-In in C# which allows a user to select a data source from a combo box and then modifies all layers to this new source.  After the add-in completes execution, viewing the layer Source Properties indicates the Instance value did not change.  However, if the MXD is closed and the user answers Yes to the "Save changes ...mxd" prompt seen in the AcrMap window, when the MXD is re-opened, the new data source is seen.
How can the change be seen on the layers without having to close and then re-open the MXD?  I have tried various refresh options (i.e. ContentsView, ActiveView) but they didn't work.
Thank you in advance.
NeilClemmons
Honored Contributor
How are you changing the data source?  Since you're updating the data connection while the document is open, I would do this by calling IDataLayer2.Disconnect first.  Then call IDataLayer2.Connect to restore the connection.  You might also try calling IApplication.SaveDocument after updating the data source.
NeilClemmons
Honored Contributor
Have you called IMxDocument.UpdateContents?
E__C_Roman
Yes, this has been done.
NeilClemmons
Honored Contributor
E__C_Roman
I change each workspace name's connection properties to the new property set:
            dataLayer = (IDataLayer)featureLayer;
            datasetName = (IDatasetName)dataLayer.DataSourceName;
            workspaceName = (IWorkspaceName)datasetName.WorkspaceName;
            workspaceName.ConnectionProperties = newMXDPropertySet;
I am not clear on how to get the Application or DataLayer from the MXDocument information I have; can you please include the code to do this?
Thank you.
MichaelVolz
Esteemed Contributor
I have the same problem with an application I created, so I am also interested in a solution to this problem.
E__C_Roman
Thank you!!  Disconnecting and then connecting worked:
            IDataLayer dataLayer;
            IDataLayer2 dataLayer2;
            IDatasetName datasetName;
            IWorkspaceName workspaceName;
            dataLayer2 = (IDataLayer2)featureLayer;
            dataLayer2.Disconnect();     <-------------------------------------**
            dataLayer2.Connect(null);     <------------------------------------- **
