Add IFeatureLayer from FeatureServer
4307
8
08-16-2016 07:05 AM
MickeyO_Neil
Hello,
I'm trying to load a IFeatureLayer from a FeatureServer in a ArcGIS Engine 10.3 Application, but I always get a "System.Runtime.InteropServices.COMException" Error Message. (Line is marked with an Error Comment).
What is the Problem of getting the Layers from the Server?
Thank You very much for your help.
    Public Shared Function GetAGSFeatureLayer(ByVal sURL As String) As IFeatureLayer
        Dim pAGSConnectionFactory As IAGSServerConnectionFactory
        Dim pConnectionProps As IPropertySet
        Dim pAGSConnection As IAGSServerConnection
        Dim enumServerObjectName As IAGSEnumServerObjectName
        Dim pServerObjectName As IAGSServerObjectName3
        Dim pName As IName
        Dim pObject As Object
        Dim pServerSymbolOutputOptions As IServerSymbolOutputOptions
        Dim pGraphicFeatureLayers As IGraphicFeatureLayers
        Dim pGraphicFeatureLayer As IGraphicFeatureLayer2
        Dim pGraphicFeatureServer As IGraphicFeatureServer
        Try
            pConnectionProps = New PropertySet
            pConnectionProps.SetProperty("URL", sURL)
            pAGSConnectionFactory = New AGSServerConnectionFactory
            pAGSConnection = pAGSConnectionFactory.Open(pConnectionProps, 0)
            enumServerObjectName = pAGSConnection.ServerObjectNames
            enumServerObjectName.Reset()
            pServerObjectName = enumServerObjectName.Next
            Do Until pServerObjectName Is Nothing
                If pServerObjectName.Type.Equals("FeatureServer", StringComparison.OrdinalIgnoreCase) Then
                    pName = pServerObjectName
                    pObject = pName.Open
                    If TypeOf pObject Is IGraphicFeatureServer Then
                        pServerSymbolOutputOptions = New ServerSymbolOutputOptions
                        pServerSymbolOutputOptions.ConvertLabelExpressions = False
                        pServerSymbolOutputOptions.PictureOutputType = esriServerPictureOutputType.esriServerPictureOutputAsPNG
                        pGraphicFeatureServer = pObject
                        pGraphicFeatureLayers = pGraphicFeatureServer.GetLayers(pServerSymbolOutputOptions) 'ERROR
                        If pGraphicFeatureLayers.Count > 0 Then
                            For i As Integer = 0 To pGraphicFeatureLayers.Count - 1
                                pGraphicFeatureLayer = pGraphicFeatureLayers.Element(i)
                                If TypeOf pGraphicFeatureLayer Is IFeatureLayer Then
                                    Return pGraphicFeatureLayer
                                End If
                        End If
                    End If
                End If
            Loop
        Catch ex As Exception
            logger.Error("GetAGSFeatureLayer", ex)
        End Try
        Return Nothing
    End Function
MickeyO_Neil
Got it:
Snippet
Public Shared Function GetAGSFeatureLayer(ByVal sURL As StringAs IFeatureLayer
   Dim pLayerFactory As ILayerFactory
   Dim pEnumLayer As IEnumLayer
   Dim pLayer As ILayer
   Dim pCurrentLayer As ILayer
   Dim pCompositeLayer As ICompositeLayer
   Try
         If pServerObjectName.Type.Equals("FeatureServer"StringComparison.OrdinalIgnoreCase) Then
            pLayerFactory = New FeatureServerLayerFactory
            pEnumLayer = pLayerFactory.Create(pServerObjectName)
            pLayer = pEnumLayer.Next()
            Do Until pLayer Is Nothing
               If TypeOf pLayer Is ICompositeLayer Then
                  pCompositeLayer = pLayer
                  For i As Integer = 0 To pCompositeLayer.Count - 1
                     pCurrentLayer = pCompositeLayer.Layer(i)
                     If TypeOf pCurrentLayer Is IFeatureLayer Then
                        Return DirectCast(pCurrentLayer, IFeatureLayer)
                     End If
               End If
            Loop
         End If
      Loop
   End Try
   Return Nothing
End Function
seria
by Esri Contributor
The code sample here below shows how to add a feature service to ArcMap using ArcObjects (click on the image below to enlarge the image):
How to Add a Feature Service to ArcMap
MickeyO_Neil
Thank you, very much, but in your example you create your own new layer.
Isn't it possible to get the layer with it's symbology/renderer from the Feature-Service?
seria
by Esri Contributor
Mickey,
Yes, that is correct. I do create my own new layer to add to ArcMap. One would definitely need an instance of a new layer object to hold the properties of the incoming feature service data, so there is definitely a need to create that new layer.
However, in order to symbolize and display that new layer the exact same way it was being displayed on the server (and I believe this is your question), you would simply not assign a renderer to it. Thus, in the code I provided earlier, all you'd have to do is  to comment out the "renderer" part of the code. This should allow the display of the layer in its "original" form. In this case, the original renderer that was used for the feature service layer on the server (the REST endpoint) would automatically be utilized by ArcMap to render the layer.
MickeyO_Neil
Hello Sami,
thank you, that's what I was looking for. But there are two more things I need to know:
If I load a Feature Service in ArcMap, the Layers have Layernames which are the Name of the Feature-Class in their SDE. In ArcObjects the FC-Names are Numbers. Furthermore the Layer have set a minimum scale.
Where do I find the FC-Name and minimum Scale in ArcObjects?
seria
by Esri Contributor
The feature class name can be accessed via the IFeatureClass.AliasName property:
http://resources.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#//0025000002qs000000
The layer's minimum scale may be accessed via the ILayer.MinimumScale property:
http://resources.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#//0012000006z1000000
A good book on ArcObjects development that you might find useful is Beginning ArcGIS for Desktop Development using .NET, by Pouria Amirian (2013).
MickeyO_Neil
Sorry, my english is not very good, maybe you didn't understand me right:
I'm writing an ArcGIS Engine Application which should load Feature-Services the same way as ArcMap. And if I load a Feature-Service in ArcMap, ArcMap creates Layers with a Layername, a Symbology and a minimum scale.
Now If I use your code from above in my ArcGIS Engine App, I only have a Feature-Class. The name and the alias-name of this Feature-Class is a number (e.g. 0). And if I create a new Layer and set the datasource, the Layer has no minimum scale.
So, my question is: how does ArcMap gets the Layername and minimum scale from the Feature-Service? Your code from above does not answer this question.
Thank you very much.
MickeyO_Neil
Any suggestions so far?
MickeyO_Neil
Got it:
Snippet
   Try
                     End If
               End If
            Loop
         End If
      Loop
   End Try
   Return Nothing
End Function
