add globeControl to arcmap
800
02-06-2012 04:33 AM
RamiAlkhateeb
Hello,
i'm using arcgis\engine 9.3 with .net c# language.
i'm trying to add some custom 3d capabilities to arcmap,
my current step is to synchronize between the 2d arcmap view and the 3d globecontrol view.
but i'm facing some difficulties 😞
arcmap needs center point and scale,
i'm setting the center point to axGlobeControl.GlobeDisplay.ActiveViewer.Camera.Target
but how to set scale?
currently i'm using this code:
but it doesnt give the expected behavior.
        void SetMapView(object sender, ESRI.ArcGIS.Geometry.IPoint TgtPoint, ESRI.ArcGIS.Geometry.IPoint ObsPoint, double spaceLeng)
            try
                ArcMap.Document.ActiveView.Activate(ArcMap.Application.hWnd);
                ESRI.ArcGIS.Geometry.IPoint[] points = new ESRI.ArcGIS.Geometry.IPoint[2];
                points[0] = ObsPoint;
                points[1] = TgtPoint;
                ESRI.ArcGIS.Geometry.Envelope newExtent = new ESRI.ArcGIS.Geometry.Envelope();
                newExtent.DefineFromPoints(ref points);
                newExtent.CenterAt(TgtPoint);
                ArcMap.Document.ActiveView.Extent = (ESRI.ArcGIS.Geometry.IEnvelope)newExtent;
                m_map.MapScale = spaceLeng * 100000; // 100000 is for test
                ArcMap.Document.ActiveView.Refresh();
                //ArcMap.Document.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeography, null, null);
            catch (Exception ex)
                System.Windows.Forms.MessageBox.Show(ex.Message);
TgtPoint = axGlobeControl.GlobeDisplay.ActiveViewer.Camera.Target
ObsPoint = axGlobeControl.GlobeDisplay.ActiveViewer.Camera.Observer
spaceLeng = axGlobeControl.GlobeDisplay.ActiveViewer.Camera.ViewingDistance
- axGlobeControl.GlobeDisplay.ActiveViewer.Camera.ViewingDistance is not effected when zoom in and out
- when the camera is not vertical above the globe surface  the "newExtent" in the previous code gives view that is zoomed in or out more than wanted.
thanks in advance.
