Activating Data Frame
1186
12-11-2011 10:14 PM
nassar1nassar2
I wrote two codes for activating the second data frame in arcmap,the first one works on but the second doesn't and I get the error "object doesn't support this action" Iwant to understand why?
1st code:
Dim pMxDoc As IMxDocument
Set pMxDoc = ThisDocument
Dim pMaps As IMaps
Set pMaps = pMxDoc.Maps
Dim pMap As IMap
Set pMap = pMaps.Item(1)
Set pMxDoc.Activeview=pMap
2nd Code:
Dim pMaps As IMaps
Dim pMap As IMap
Dim pActiveView As IActiveView
Set pActiveView = pMap
Set pActiveview.FocusMap=pMap
JimBarry
moving to ArcObjects forum  -jb
SiqiLi
by Esri Contributor
The 2nd code fails at Set pActiveview.FocusMap=pMap . You can set IActiveView.FocusMap property, only if current active view is in the page layout mode.
Here is the code I would use:
Set pActiveView = pMxDoc.ActiveView
If TypeOf pActiveView Is IPageLayout Then
   Set pActiveView.FocusMap = pMap
ElseIf TypeOf pActiveView Is IMap Then
   Set pMxDoc.ActiveView = pMap
End If
