ACCESS DENIED PROBLEM
2165
11-12-2012 03:37 AM
TubaKumbara
on Server A I have ArcGISServer 10.0
on Server B I have ArcGISServer 9.3.1
There is an image service created from Raster mosaic dataset on Server A
And I created a GlobeService on Server B. The globe document of This globe service has data which comes from Server A (image service)..
I have lots of globe services in Server B, created in this way.
But when I try to load some of the globe services from Server B to GlobeControl in VB.NET, I get this error :
"Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))"
I don't find any solution.
If there is a problem with the globe services from Server B or image services from Server A,
I think that all of the globe services or image services shouldn't work.Am i wrong?
But in this manner, for example if i have 5 globe services which were created from image services,
3 of them work properly but 2 of them give this error.
I all controlled the agsusers and agsadmin and security of the data directories ..There are no problems..
what may the problem be?
Please help
AlexanderKeyel
This is probably too late to be of use, but this was the most relevant search result when I searched "Access is denied", so I'm answering now, in case others have this problem, too.
I got an "Access is denied" error when I tried to use arcpy.Mosaic_management (mosaic tool) with more than one input
e.g.:
path1 = "C:/path/to/file/file"
path2 = "C:/path/to/file2/file2"
paths = [path1, path2]
first_raster = "C:/path/to/first_raster/first_raster"
arcpy.Mosaic_management(paths, first_raster, "FIRST")
When I changed it to:
arcpy.Mosaic_management([path1], first_raster, "FIRST")
I no longer got the error. (in Python, you can create a loop over the path list, and can quickly mosaic all the rasters together.
I don't know why the mosaic tool cannot handle more than one input when I try to use it, but I also recall having this problem in the past.
NOTE: I'm running ArcGIS 10.3.1 on Windows 7, and am not running anything on a server.
