Fitur Identity dan Combine error
1217
03-18-2018 07:32 PM
BukhariBukhari
kenapa fungsi identity dan combine raster tidak bisa?saya coba combine 2 layer raster selalu muncul error
ArshaYuditha_Amiranti
Hi Bukhari Bukhari
Dalam penggunaan identity tool, pastikan Input Feature dan Identity Feature adalah polygon, lalu centang parameter Keep relationships, maka hasilnya akan terpisah menjadi dua field yaitu LEFT_ploy dan RIGHT_poly.
Mungkin bisa lampirkan pesan error nya?
English:
In identity tool, make sure that Input Feature dan Identity Feature are polygon, then check the Keep relationships parameter, then the output feature class will have two additional fields, LEFT_poly and RIGHT_poly. Perhaps you able to also attached the error message?
