Using Reclassify to do NoData Values
2288
09-13-2023 06:29 AM
SoratoMarques
I have one raster and would like to transform all values between -0,9 - 0 like 1 value, and 0 - 0,9 like NoData.
How can I to this in python?
Thank´s
Tags (1)
JimCousins
SoratoMarques,
 This is a standard function that has an arcpy sample as part of the help about this function.
Do you have the spatial analyst or 3D analyst extension? One of these is necessary for access to the tool.
If none of this helps you solve this issue, what is the error or problem with the methodology?
Regards,
 - Jim
SoratoMarques
I have spatial analyst!
this code below no work properly:
arcpy.gp.Reclassify_sa(negativo_tif, "Value", "-0,900000 0 1;0 0,900000 NODATA", reclass_negavt_tif, "DATA")
KenBuja
MVP Esteemed Contributor
I would suggest using the Con tool instead
JimCousins
KenBuja - excellent call. I agree with you.
