Unable to update source path of a layer file using "Set Data Source" in the layer properties
623
01-15-2024 07:20 AM
Labels (2)
StevenBradbury1
Hello all. I am attempting to update the source path of a raster layer file using "Set Data Source" in the layer properties. When I browse to the appropriate feature in the new geodatabase, select it, and hit "Add", the browse window refreshes and nothing happens, the source does not update.
I am able to bring in and view the new source and there is no problems with it, so I'm unsure what the issue is.
This method has worked for every other layerfile in the new source geodatabase except for one.
