Spatial Reference short description
1458
08-15-2022 12:44 AM
Andrew_Needham
When using Model Builder is there a way to get the short description of the Spatial Reference? I'm trying to add this to an attribute.
For example when using the tool "Create Spatial Reference" the string output is:
PROJCS['GDA_1994_MGA_Zone_56',GEOGCS['GCS_GDA_1994',DATUM['D_GDA_1994',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMET ....
But is is shown as:
when hovering over it, which is is what I am after as this is more readable.
Any thoughts on how to achieve this?
RhettZufelt
MVP Notable Contributor
Not sure about model builder, but can extract that from the string output:
stringout = """PROJCS['GDA_1994_MGA_Zone_56',GEOGCS['GCS_GDA_1994',DATUM['D_GDA_1994',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMET"""
stringout.split("'")[1]
RhettZufelt
Andrew_Needham
Thanks RhettZufelt that worked
