Selecting max value in SQL query by group in ARCMAP
3674
04-10-2022 03:17 PM
Labels (3)
khalidechlouchi
HI, I am working with a feature class stored in a File Geodatabase In ArcGIS 10, . I want select the maximum value by ID like the example below:
I tried the following sql query but without result :  VALUE in (SELECT max(VALUE) FROM featureClass GROUP BY ID)
How can I solve?
Thanks.
IDVALUE
15
12
110
23
24
26
316
320
34
JeffHouser
Just to confirm, your values in the above table are left-indented, suggesting text.  Are your values text or numeric values.  Numeric values usually displayed w/ right-indent.
Regarding your sql, maybe change your sql from:
To
 [Value] IN (SELECT MAX( [Value] ) FROM featureClass GROUP BY [ID] ).
-Jeff
khalidechlouchi
Thank you for your feedback, the values are all numeric, I tried your solution, but it didn't work.
DuncanHornby
MVP Notable Contributor
I don't believe File GeoDatabases support GROUP BY when selecting rows in a table? A quick search of this forum and GIS SE and you see many threads about the issue.
If you want to create a table of just that data (which is different to selecting rows) then you can use the summary statistics tool as shown below:
khalidechlouchi
Thank you DuncanHornby,  you are right, GROUP BY is not supported in geodatabases file and shape files, I think I will try to do it on personal geodatabase with ACCESS.
