SELECT 'NULL' on a joined table
1734
05-14-2024 04:44 PM
nimitz
Hi all, I have joined a sde feature class to a .txt. The .txt file has several hundred 'NULL' values in the field I want to select from. However, I want to select NON-NULL values. ArcMap won't let me select NULLs. After that I would want to flip the selection set to show every record that has a value.
WINDOWS 10, acrmap 10.8.2
Thx
JeffHouser
Nimitz,
In ArcMap, Selection - Select Attributes, cant you use "field" is not null to select features with non-null values?
~Jeff
JeffHouser
Nimitz,
~Jeff
nimitz
Dooood!! You 'da man!!😀  Worked like a charm! Now, if I could automate this process...
I owe you a beer!
RhettZufelt
MVP Notable Contributor
You can if you want to use python.
Add Join.
Select by Attributes.
R_
