select data that overlaps with others
1206
06-07-2020 03:11 PM
Annalee
Hi all,
I have put two datasets in ArcMap and I want to find the observations that overlaps to each other. For example, I have a street and would like to select all the properties on that selected street. Can anyone help?
DanPatterson
MVP Esteemed Contributor
amongst many options, you can use
Select Layer By Location—Data Management toolbox | Documentation available in arcmap and Pro
various intersection tools etcetra are available depending on what you want the to do with the data
... sort of retired...
Annalee
Hi Dan, thank you for your prompt response.
Is there any way that I can select the properties that are located within 0.5 miles from the selected streets? I have a straight line and would like to calculate distance from the nearest street to properties and select the properties within 0.5 miles. Thank you.
DanPatterson
Anna lee‌ ,.. you can specify a distance threshold, it is one of the options  BUT it won't do road distance, you would require the Network Analyst extension to do that
