Raster Calculator
1251
03-10-2022 01:14 AM
pınarspor
Hello everyone!
I have different water depth maps for a certain area and there are structures in this area. I want to calculate the water depths for each of these structures separately.
I will be grateful if you could help me
JayantaPoddar
My Assumption
1. Water Depth Map is a Raster layer, where each pixel value refers to the water depth.
2. Structures: Point feature class (Vector data).
Then you could use Extract Values to Points.
Here are a few other options How To: Extract raster values to point locations in ArcMap (esri.com).
In case my assumptions are incorrect, please elaborate on the details of the data that you have.
Think Location
DanPatterson
MVP Esteemed Contributor
If the structures are polygons, then
Zonal Statistics (Spatial Analyst)—ArcGIS Pro | Documentation
maybe in conjunction with
Tabulate Area (Spatial Analyst)—ArcGIS Pro | Documentation
... sort of retired...
