Publish map service using Encrypted sql database coonnection
1002
07-15-2021 08:52 AM
Labels (3)
JayAppusamy
Version 10.6.1 Server EditorServer Editor(ArcMap/Portal for ArcGIS/ArcGIS Server)
Publishing map service via ArcMap is prompting for 'Copying data to server' after sql database connection is encrypted using server certificate, Please see attached image
Note:
  • SQL Database connection is encrypted using server certificate
  • Registering database to data store works ok
  • Publishing map service was working fine before database encryption without above prompt.
Can anyone suggest how to resolve this issue?
