Please help, cannot paste a shape file in data view arcmap 10.5
1092
01-30-2024 11:19 AM
golbi_nachr
please help, my Arcmap 10.5 cannot paste a shapefile when i copied in data view. anyone has solutions? i try to uninstall the apps but the problem not solved yet
i cannot paste the polygon, polyline, and point when i start editing features
ChrisUnderwood
Hello @golbi_nachr , what License level are you using ? From memory, you need ArcInfo or ArcEditor to edit, and you cannot edit with ArcView.
JeffHouser
The information in your post is a little limiting to automatically answer your question.  Please refer to CU's reply. Based on your attached images, you're editing the "LC_Bapp_Nov22_KJ" featureclass, in which you selected one feature from the "planted"  featureclass to then paste into the "LC_Bapp_Nov22_KJ" layer.  Is there a query-filter on the "LC_Bapp_Nov22_KJ" layer?  If so, remove the query filter, and try again.  Note, your "planted" and "LC_Bapp_Nov22_KJ" feature classes look "ugly", meaning lots of slivers and heavy w/ vertices, etc...  The latter is usually not an editing issue and something ArcGIS can handle, but maybe not?
~Jeff
