Path Distance problem
2573
02-16-2023 12:51 PM
Labels (2)
RobertoFilloramo
I am using Armap 10.8.2 and my issue is the result obtained from the path distance tool.
it appears a warning massage stating: Cost Cells with zero or negative values were encountered. Not all source cells may have been processed.
The used data are:
-shp point as origin;
-DTM (used as surface raster and vertical surface input);
-Slpoe (used as cost raster).
I used to process the same data in Arcmap 10 and I've never had this problem.
How can I fix it?
I attached an image of the result.
Thank you in advance @DanPatterson
DanPatterson
same coordinate system for all?
... sort of retired...
RobertoFilloramo
Yes, all the same coordinate system
DanPatterson
Path Distance (Spatial Analyst)—ArcGIS Pro | Documentation
too many other variables then to provide further comment (eg cell size etc)
you might want to have a look at the newer tools which provide more control over the analysis
Distance Accumulation (Spatial Analyst)—ArcGIS Pro | Documentation
