Hi all,
I am having a bit of difficulty with arc map 10. Keep in mind I am no expert. I used to use it a lot in my early years of my PhD but I have had to jump back into it now I am finalising some chapters.
I am trying to rename a few layers and fields. It appears layers are no issue. I just go into properties and general and rename the layer. However, I have had issues renaming fields. I go into properties and fields and choose the relevant field I wish to rename. I then rename the alias category. The new name i put under alias shows up on the attribute table and also in symbology but the layer table of contents still has the old field name, as does the legend when I switch to data view to export a map. Does anyone know how to change the field name so it updates? I don’t want to have to import everything again from scratch.
I appreciate all your help
Luke
