Patch S-1061-HF-000004907.msp
1462
01-26-2021 03:59 AM
EmilioTomeBlasco
Is patch S-1061-HF-000004907.msp for ArcGIS 10.6.1 solved in 10.8.1?
George_Thompson
Esri Notable Contributor
Here is the link to the information: https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDEwNTQ3MQ==
It should also be fixed in 10.8.1, if you are experiencing the issue again I would work with Technical Support to investigate.
--- George T.
George_Thompson
This is something that would need to be asked to Esri Technical Support.
Do you have a specific defect # related to this?
--- George T.
EmilioTomeBlasco
Hi George,
I just Know that this HotFIX is for the BUG-000105471, and it was fixed in the 10.7.1 version.
Thanks for your answer
George_Thompson
--- George T.
