Measuring change between shapefile attributes
3503
02-27-2021 10:18 AM
ZJKosel
Hello everyone,
I have two shapefiles, both of the same county, and each one is divided into about 20 subdivisions. One of these is from 2016 and the second one is from 2020. I'm trying to find a tool that would be able to measure or highlight changes in the boundaries or borders of the subdivisions within the county over time. Most things I've found are for comparing entire features instead of directly comparing attributes within two shapefiles.
I'm using ArcMap 10.6.1
Thank you,
Zachary
DanPatterson
MVP Esteemed Contributor
An overview of the Data Comparison toolset—ArcGIS Pro | Documentation in Pro at least, has several difference tools.
An overview of the Overlay toolset—ArcGIS Pro | Documentation overlay options don't seem appropriate, except perhaps Intersect.  Symmetrical would only be useful if there are overlaps.
... sort of retired...
DanPatterson
Find Identical (Data Management)—ArcGIS Pro | Documentation  Pro
Find Identical (Data Management)—ArcMap | Documentation (arcgis.com) ArcMap
and join the result back to the original table.
What isn't identical is different
ZJKosel
Thanks for the quick response! However, the Find Identical (Data Management) tool seems to just list the fields that have duplicates. Since I already know that all the subdivisions have slight changes in some ways to their geometry/geography, I'm trying to narrow down to where the exact locations of change are within the subdivisions of the two county shapefiles.
Thank you,
Zachary
jcarlson
@DanPatterson's first link is the one you want. The corresponding ArcMap page is here.
As far as measuring the change, the output match table gives a rough idea of how close a match the features were between the two datasets, but in spite of it being given as a number, it's not really a measurement.
You can optionally get some additional fields quantifying the degree of change if you input a change tolerance buffer, but I don't always find that to be helpful. It really depends on your data, but there are times when a change in shape can be more important than a lateral shift.
If you want to look beyond shapefiles, take a look at what's known as a Hausdorff distance. You'd need your layers in a DB of some sort, but ArcGIS can export to SpatiaLite, which is a self-contained database file. SpatiaLite does support calculating a Hausdorff distance between two geometries, and can be quite useful for the "measuring" part.
- Josh Carlson
Kendall County GIS
DanPatterson
ZJKosel
Thanks for the links! I focused on other projects for a while, but when I returned to this one, the Symmetrical Difference tool did what I had in mind.
Thank you,
ZJKosel
