Load a file in Select By Attribute cause issues
1689
02-04-2021 12:37 PM
DEAF_PROBERT_68
Honored Contributor
I'm trying to save a file in the Notepad to build my Select By Attributes so I can save them for later use.
Problem I don't know what to save which file type it can read ?
My question is which file type do I need to save as what ?
I did write it down in Windows 10 and copy it and save it in Citrix Enterprise server
This is what it gave me
it gave me all the garble !!!
DanPatterson
MVP Esteemed Contributor
Can you type ascii text in Notepad?  Notepad is for ascii text.  It seems you are reading or writing in a different codepage.
PS google     Notepad++   and download it.  It is better than builtin Notepad
... sort of retired...
DEAF_PROBERT_68
Honored Contributor
I cold not get it to work but I found out that when you save it to a file within the Select By Attribute, the extension is .exp.  I found one of my old expression I had so I fix it but it is still not work...
DanPatterson
and what would the expression be?
DEAF_PROBERT_68
Honored Contributor
At first it didn't work but I had to load the old one with the .exp and the copy and the paste of that expression I wrote and save as a new one.  It is working fine now.
