Import ArcGIS Pro Layout into Desktop
1428
10-13-2023 02:03 AM
StuartMoore
is there a way to import an ArcGIS Pro Layout into ArcGIS Desktop without recreating it?
thanks
Tags (1)
DanPatterson
MVP Esteemed Contributor
maps can ArcMap frequently asked questions—ArcGIS Pro | Documentation
Can I use maps authored in ArcGIS Pro in ArcMap?
Yes. You cannot export a map from ArcGIS Pro as a map document (.mxd). However, after you share an ArcGIS Pro map as a web map, you can open it in ArcMap.
Layouts, no.
... sort of retired...
DanPatterson
Layouts, no.
