I can not download ArcMap
2193
01-07-2024 10:33 AM
EsadHajTaleb
Hi, I just want to download ArcMap and I can't because there's no option to download it in "Downloads" tab in My Esri. I'm using "ArcGIS for Student Use" licence.
DEAF_PROBERT_68
Honored Contributor
Why would you want to download Arcmap ? ESRI is planning to phase it out and will no longer support after March 2026.
Everyone is moving on to ArcGIS Pro and make the transition from ArcMap to ArcGIS Pro
https://www.esri.com/arcgis-blog/products/arcgis-desktop/announcements/arcmap-continued-support/
Unless if you want to work with it. You might need to contact them if you should need it.
EsadHajTaleb
Thank you to answer my question
I would want to download it because I will use it in my department (City and Regional Planning department)
[email protected] Can this email help me if I ask to give me permission to download it?
abureaux
MVP Frequent Contributor
The download is still there. Go to Downloads > All Products and VersionsArcGIS Desktop (ArcMap)
PROBERT68 is correct though. ArcMap is on its way out, which is why it isn't as obvious any more. If your department hasn't already begun so, they may wish to start looking into ArcPro.
EDIT: May as well link this here: ArcMap Continued Support
EsadHajTaleb
The only option I have is ArcGIS Pro and when I click to "All Products and Versions" nothing shows except these three: ArcGIS Pro, Cityengine, and licence manager.
