How to use the Aggregate Points tool
1619
05-18-2022 11:20 AM
KaraleeCorbeil
Hello,
I am trying to use the aggregate points tool to combine several points into a polygon shape. When I run the tool, it creates a polygon on my table of contents, but when I zoom to the layer it goes back to my entire globe and the attribute table is blank. I am wondering if it has to do with my aggregate distance (1000 meters) or that I'm working with projected data...
Thank you for any help!
RobertBorchert
Honored Contributor
Are you working from shape files.  I have never used the tool before 5 minutes ago. I just ran it on 240 points scattered over a region in the US.  I did it at 1000 and it only made  3 polygons, 10000 it made 24, and 100000 it did only 2 (one very large)
check to make sure you do not have any multipart points.
If you are using a shape file.  Create a new ShapeFile based on the originals attributes and use the data loader.
If your in a database, compress the database.
What projection are you using? If you are using a small regional projection that may cause an issue if parts of the polygon go outside of it.
KaraleeCorbeil
I think the issue is that I do not have enough data points. I am not working with a shapefile and my projection should be large enough that I do not have any issues.
