how to choose projection for map layer
4024
03-01-2022 07:14 AM
RickCheney
I have a map of southern Ontario, Canada.  The map has many layers.  In ArcMap, when I use the Analyze tool, I get an error message stating:
"Layer's data source has a different projection [ . . . ] than the data frame's projection"
Various layers are:
GCS_WGS_1984
NAD_1983_UTM_Zone_15N
NAD83(CSRS98)
GCS_North_American_1983
Do I need to change the projection for all layers and the Data Frame so they all match?  Which projection should I use?  Is there a specific projection for southern Ontario?  Or can I just choose what looks correct?  For example, when the data frame projection is:
WKID: 26915 Authority: EPSG
Projection: Transverse_Mercator
the map looks similar to online maps of Ontario.  When I change the data frame to:
Geographic Coordinate System:  GCS_North_American_1983
the map looks stretched horizontally.
Tags (3)
DanPatterson
MVP Esteemed Contributor
Start with the map frame, set its coordinate system to zone 15 and even if the other layers are in a different coordinate system, they will project-on-the-fly to it.  In arcmap and Pro, the first layer added to a map, sets the coordinate system for the map if one isn't set previously.
Search the Ontario sites, they do  have data available in a variety of formats, but read up on the metadata for each site...
... sort of retired...
DanPatterson
What type of data are you using? that is anything from the Ministry of Ontario
Ontario GeoHub (gov.on.ca)
If everything fits into 1 UTM zone, then that would be fine.  Just don't use Web Mercator if you intend to do any measurements of distance or area.
RickCheney
Thanks Dan!   Most of the data is from Ministry of Ontario.  Do you mean, for example, I could make the Data Frame and the layers all NAD_1983_UTM_Zone_15N
DanPatterson
RickCheney
Thank You!  That worked.
