HOW CAN DELECTED LINES WITH ONE STEP
2317
10-23-2020 05:22 AM
PintoJoão
Hello People of GIS
How can i delete more quickly the selected line(vertical line before the last) without one by one? 1º img
Or
Delete with one step the last vertical line(selected) 2º img
best regards
João
LukasFalk
Hello João,
From what I've gathered you are looking for a way to delete multiple line features at once as opposed to doing one at a time.  I may be oversimplifying your inquiry but if this is in fact what you are looking to do it can be done by holding Shift and then selecting the other lines you want to delete.  Once you have selected all the lines you want deleted right click one of them and click Delete.  This will remove all the lines you have selected at once.  Let me know if this isn't what your inquiry was about and I will try to get you the answer you need.
I hope this helps!
Lukas
PintoJoão
Hi Lukas
Thank you so much for your attention to this case, but what you said is what i have been doing.
I need some help tool or another work flow to do what i want in a few seconds.
Best regards Lukas
