Grayscale ECW opacity layer not correctly displayed
1332
01-10-2022 06:13 PM
RichardNicholls
A problem we've had for ages is whenever we load a Grayscale ECW into ArcGIS with an opacity layer, the default is for it to load as a colour and use the opacity as the green/blue values and the grey as the red (see attached). Is there some way for Arc to default as greyscale correctly?
If I generate a mosaics without opacity, it loads correctly, but opacity is needed to remove the null areas.
We're using ArcGIS Desktop 10.6.1
evemarwernick
If you haven't solved it yet, I think you can get the results you want by changing the RGB Composite values:
Red: Grayscale
Green: Grayscale
Blue: Grayscale
Alpha AllOpacity
Regards,
Evemar Wernick
