Geographically Weighted Regression (GWR)
1998
09-28-2023 04:34 AM
WaleedAbbas
Greetings
When frequently executing the tool "Geographically Weighted Regression" in ArcMap Spatial Statistics, the following error message appears:
ERROR 040008: Input value is out of range.
I can't find the reason behind this message.
DanPatterson
MVP Esteemed Contributor
040008: Input value is out of range.—ArcGIS Pro | Documentation
One or more of the input parameter values is incorrect or out of range.
So what parameters were you using and what was their ranges?
... sort of retired...
WaleedAbbas
I'm sure the input parameters (one dependent and four independent variables) are correct. They work well in both Explanatory Regression and OLS. Moreovere, each other work well in GWR , but when be together in a single GWR process, the error appears.
I'm working on ESRI data
Dependent: Voter turnout
Independents: Median age, Per capita income, Buying American is important to me percent, and Edu. Bachelor percent.
DanPatterson
Geographically Weighted Regression (GWR) (Spatial Statistics)—ArcGIS Pro | Documentation
any of the data multipoint? (The tool does not work with multipoint data.)
any missing values? (These fields must be numeric and have a range of values.)
what are the ranges of the values for each variable?
Plus... many other considerations in the help topic and tool input parameters to consider which might give rise to errors
WaleedAbbas
Deep thanks.
I will carefully review the tool help to discover any considerations which might give rise to errors
