Fixing error
1573
07-01-2021 04:28 AM
Malebu
Greetings everyone
I have a layer in which I received an error message (see below). I repaired Geometry but the problem still there and the layer doesn't load
"One or more layers failed to draw:
There was a problem drawing the shapefile. Drawing aborted."
Can you please asssist
JayantaPoddar
Could you check if exporting the shapefile to a Geodatabase Feature Class resolves the issue? You could use Feature Class to Feature Class tool.
Think Location
DrVSSKiran
Please follow this link for solution and workaround.
https://support.esri.com/en/technical-article/000005082
JayantaPoddar
Think Location
Malebu
Hi Jayanta
exporting shapefile to Geodatabase (Feature class to feature class) worked perfectly. I am no longer getting the error message and the layer uploads oerfectly.
Thank you so much
