Field calculator
1194
03-12-2022 12:49 PM
FOUADHAMDAN_SAAD
Hi community....
I tried to applied field calculation using Python in field type "text" as show below:
Expression:
reclass (!code!)
code block:
def reclass(code):
if (code =13):
return "Industrial"
elif (code = 16):
return "Urban or Built-up Land"
elif (code = 0):
return "Unclassified"
I got an error, please I need your help.
Thank you in advance.
DanPatterson
python parser
def reclass(code):
    if code == 13:
        return "Industrial"
    elif code == 16:
    elif code == 0:
equality check is ==
assignment is =
Error message would be useful in case this doesn't cover it.
... sort of retired...
DanPatterson
python parser
def reclass(code):
    if code == 13:
        return "Industrial"
    elif code == 16:
    elif code == 0:
assignment is =
FOUADHAMDAN_SAAD
Thank you @DanPatterson , I appreciate you.
