Elevation Disappear in contour Lines
800
06-03-2021 01:12 AM
ZiaAl-Moharbi
Hello to all,
I'm using arc map desktop. I create contour lines from (DSM) raster data using 3D Tools then I converted to CAD file, the problem is when I open the drawing the elevation represented with 0 value , and I want to count the volume depending on the elevation for the contour lines, what is the expected issue you think?
