Cut Poly error, ArcMap 10.5
1044
01-22-2019 01:04 PM
AmeliaNewsam
I am trying to cut a polygon, which is editable, and which is being separated into two distinguishable parts, when I suddenly start getting the error message "the cut polygons task could not be completed."  There is no further explanation.  I try saving and closing, reopening, multiple times, but still get error message.  This is a poly that I've been cutting for hours (cutting pieces out a single poly, creating hundreds of smaller polys), so it has nothing to do with environment, editability, etc.
Thanks!
Tags (1)
AmeliaNewsam
So it just started working again.  Essentially I did some other things (create features, etc.) for a while and then went back to the cut poly task.  Now it's working.  It seems like a bug.  ?
