Converting <Null> values to empty field in ArcMap 10.8.2
1865
06-10-2024 06:52 PM
Labels (3)
CameronKoehler
I have several fields in my road centerlines that the column has several <Null> values.  I am needing these fields to be just populated empty fields.
JeffHouser
Cameron,
There are probably a few ways to do.  One way:
First select all features that have <NULL> values for a given field. Then in the field calculator "VB Script", select the field.  Then type ""    and click Ok.  That should change the <NULL> values to empty fields
~Jeff
JeffHouser
Cameron,
~Jeff
CameronKoehler
After overthinking this, I had just discovered that this worked on my own.  Thank you for the help as well!
