auto-generated legend
1572
06-29-2020 12:37 PM
by Anonymous User
Not applicable
This is a periodic problem I've been having with ArcMap.  When beginning a new map the program auto-generates a legend, scale bar, and north arrow.  The scale bar and north arrow are selectable and easily removed, but the legend isn't.  As I add layers to the TOC the legend grows, peaking out above the map in layout view (see attached image).  I've been working around it by simply covering it up with a rectangle, but wondering what is causing this?
DavidPike
MVP Notable Contributor
I'd recommend resetting your normal.mxt, do a search for it and i'm sure you'll find a good explanation of the process. If not, let me know and I can write it up (it's not long-winded I just don't want to!).
by Anonymous User
Not applicable
Ok, so I ran into a problem with resetting normal.mxt - I'm running ArcMap off a remote server and not directly from my desktop.  Therefore I don't think I have access to the Esri application program folder.  Is this something an administrator would be able to do for me?
DavidPike
Hi Sam,
The local profile stuff should be in your C:\ drive in your %APPDATA% folder (you can just enter %APPDATA% in the path window to navigate to it).
This is generally disabled in organisations to stop this kind of meddling, but you may be lucky and it is just a hidden folder.
If it comes up with a permission issue, definitely raise it to your IT dept and ask them to go through the workflow or to grant your access (takes less than a minute if they were to reset normal.mxt for you).
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows 10
by Anonymous User
Not applicable
Thank you David, I'll give it a try!
