Arcmap v10.5 problem
1594
6
09-13-2025 11:00 AM
MoTarek2025
Hey there,
I have an issue when i add basemap in arcmap. Nothing appear in the screen when i repeated it ،nothing done.
I deleted it and reinstall and  i face the same problem.
I wish someone here helps me.
CodyPatterson
MVP Regular Contributor
Hey @MoTarek2025
Is this a custom base map, or one that was default with ArcMap?
Cody
MoTarek2025
I get it when i choose add date>basemap>imagery>add
And i don't get any maps under (layer menu)
Todd_Metzler
Hello,
Is the subject correct?  ArcMap (aka ArcGIS Desktop) 10.5.x retired a very long time ago. ArcGIS Desktop (ArcMap) Life Cycle .
MoTarek2025
I know that but i wanna a solution only .
GeeteshSingh07
DavidSolari
Grab a traffic scraping tool like Fiddler and see what's logged when you try to add the basemap. If you're lucky you'll get a clear error, or there'll be a mismatch between the basemap service ArcMap is trying to use and the one your org should be using.
If there's no issues with the data ArcMap's downloading then you're up a creek, 10.5 is wildly out of service. You can try purchasing your own imagery and making your own basemap tile cache, or use this as a cudgel to get your org onto 10.8.1 where you can squeeze out some support for issues like this.
