ArcMap always on top - very annoying!
1792
05-17-2024 11:23 AM
MatthewLeonard
The ArcMap window stays on top of all other windows when it is up. Normal Windows behavior is: when I click on an open app from the taskbar, it comes to the top so I can see it on top of other windows. But if ArcMap is up, it stays on top and keeps hiding other windows until I minimize it. I cannot figure out how to stop this behavior, but I would really like it to stop.
ArcMap 10.8.1, Windows 10 Enterprise
MErikReedAugusta
MVP Regular Contributor
Do you mean the primary ArcMap window, itself, or something like an attribute table that you've dragged out to a separate window?
If it's the first one, that's certainly odd behavior and I don't have any suggestions.  It sounds to me like something is bringing it forward, not that it's staying forward (subtle but important distinction).  I'd recommend reaching out to ESRI support.
If it's the second one, that's essentially by design, I think.  See below for more.  N.B. I'm using Pro, now, but the behavior I describe below was the same back when I used ArcMap, and for basically every program that has "child" windows like this.
For example, I have two monitors.  Generally, I keep my main instance for whatever I'm working on open in the monitor on the left.  Anything I need to reference goes on the monitor on the right.  Sometimes that second monitor might be an attribute table, sometimes it's another Pro project, and sometimes it's some other file entirely, sometimes it's some combination of the above.  The important one for this discussion is when the second monitor has an attribute table or anything else that comes from the primary project (i.e., it came from the left window, and I dragged it over to the right).
Say I had a PDF open on the right hand side that I was referencing, but now I've opened an attribute table that is on top of the PDF.  So far, so fine, because when I click Pro on the left window to do work, I'm referencing the attribute table on the right, and both are on top.  But let's say I need to go back to that PDF for something.  Instead of closing the attribute table, I just click on the PDF to bring it to the fore.  Now I'm looking at the PDF on the right and Pro on the left.  Then I click back to Pro (or ArcMap, in your instance) on the left window to resume working.  Wait, where'd my PDF go?  It's now behind the attribute table, because as far as Windows is concerned, that attribute table on the right and the main project on the left are the same thing.  So it just brought a single thing to the fore of both monitors.
Because of the way Windows (and most other OSes) handle, well, windows, you're always going to get that behavior if you have "child" windows that belong to a primary window somewhere else.
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
MatthewLeonard
It's the main ArcMap window staying on top (and the attribute table along with it, if I've detached the attribute table).
MatthewLeonard
Interestingly, this behavior does not happen from the beginning when I've just restarted my computer and then opened ArcMap. But at some point a bit later, after opening a few other apps and using ArcMap some, this staying on top behavior begins. I'm not sure what makes it happen.
What also happens, every so often: While ArcMap is minimized, the ArcMap attribute table will pop up on top of everything else on its own, without me clicking on it. This will be just the attribute table when it's detached from the main window. This seems to happen on a regular basis, every few minutes or so. The first time this happens is possibly the when the "staying on top" behavior begins...it seems like they might be related. But I don't know why this happens or what triggers it.
